DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Technical Help & Information > DIY - Do It Yourself > Oil Change DIYs!
Thread Tools Search this Thread
Old 08-26-2006, 10:26 PM
BadStratRT's Avatar
BadStratRT BadStratRT is offline
The DodgeFather
Dodge Forum AdministratorHall of Fame Member
1992 Plymouth Laser
My Garage
Vehicle: 1972 Dodge Demon 340
Send a message via AIM to BadStratRT
Default 1991-1996 Dodge Stealth RT, TT or NA
Done by:
thestealth
Performed on:
1992 Dodge Stealth RT Twin Turbo, 1992 Dodge Stealth RT NA
Step 1. Run engine to normal operating temperature.
Step 2. Shut off engine. With car parked on level ground, lie in front of the car on the drivers side. Slide a short catch pan under the car. With a flashlight, locate the oil pan drain plug (socket size forthcoming). Unscrew plug, using a 17mm wrench, try not to drop it in to oil catch pan. Just in front of the oil drain plug is the filter, it will be hidden from view, but should be no trouble to find. If the last person didn't over tighten the filter, it should come off pretty easy, if not, you will be able to use a filter wrench. Upon removing the filter, inspect it to make sure the filter gasket came off with the filter.
Step 3. Allow oil to drain. A warm engine will drain much faster and more thoroughly than a cold engine.
Step 4. Clean and replace oil pan drain plug. Using a small amount of fresh oil, lubricate the gasket on the new filter and replace filter.
Do not over tighten filter, hand tight will suffice.
Step 5. Fill with 4.5 quarts of the oil of your choice. I use Valvoline full synthetic in my Twin Turbo and Valvoline high mileage blend in my non turbo. Use whatever suits you best. Run engine, to cycle oil through new filter. Check oil level with enging shut off, fill as required.
Note: DO NOT use Fram brand filters. I know personally of one engine failure due to the filter check valve coming apart and clogging the oil pump, blowing the engine. I have read about several Fram filter failures online. Use OEM filters from Mitsubishi. They will cost a little more, but for the piece of mind, it is a small price to pay.
DodgeStealth
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
The New Detroit Autos Examiner!
1972 Dodge Demon 340-1983 Dodge Mirada 340-1992 Plymouth Laser RST-2002 Dodge Stratus R/T Coupe-2006 Dodge Ram 1500 Laramie
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Tags
1991, 91, 92, dodge, forum, na, oil, pan, plug, rt, stealth, steath, tt, ttcom, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
