'95 Neon Fuel Pump not running
I have a 1995 Dodge Neon SOHC that died on me. I have troubleshot it to the PCM not turning on the Fuel Pump& Auto Shutdown relays. I replaced the PCM and this did not solve the problem. I can ground the control wires for both relays at the PCM connector and the pump will run. What would cause the PCM to not enable the Fuel Pump Relays?
RE: '95 Neon Fuel Pump not running
sounds like the same problem as me but i'm in a ram 1500there's three sensors to look at 1)camshaft 2)crankshaft 3)neutral safety.I think your car is too old to do the obd thing. Cycle the key on-off on-off on leave it on watch the engine light and the odometer count the times the engine light goes on there will be a pause between the numbers.if the odometer says NoBu5 it's probably a PCM failure,maybe not programmed properly?Sorry don't know much more for you.Good luck.let me know the results
