PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
Fuel Injector Question
Old 10-07-2006, 08:02 PM
dergani's Avatar
dergani
dergani is offline
Default Fuel Injector Question
I got a set of 8 fuel injectors (brand new and working) from a 360 intake manifold. I want to use them with my 318 manifold (92 W150 RAM) but the electric connectors to the harness and the injectors seem to have a different plastic fit pattern. It isnt that much of a diff. , can I just trim the plastic and use them anyways? Or are they specifically different between the two types of motor?
Old 10-08-2006, 11:27 PM
superdak05's Avatar
superdak05
superdak05 is offline
Default RE: Fuel Injector Question
you will need to grab the wiring harness for this upgrade also you might what to get the pcm.
Quick Reply: Fuel Injector Question
