PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
545RFE Transmission?
Old 01-17-2007, 09:08 PM
jchambers's Avatar
jchambers
jchambers is offline
Default 545RFE Transmission?
Anybody know how to hold 3rd gear with the 545RFE transmission? We're trying to do some dyno pulls on a supercharged Ram 1500 and we're finding it impossible to get it to hold gear. What gear does the trans default to if unplugged? I've found some add-on controllers but they tend to be pretty expensive.
Thanks.
Old 02-11-2007, 01:50 AM
superdak05's Avatar
superdak05
superdak05 is offline
Default RE: 545RFE Transmission?
when you unplug the trany it goes into limp mode stays in second gear. . when dueing dyno pulls turn the od or tow haul switch off. this should help
Quick Reply: 545RFE Transmission?
