DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Ramcharger, Trailduster & Power Wagon
Thread Tools Search this Thread
Old 10-15-2009, 01:48 PM
DonJon's Avatar
DonJon DonJon is offline
1985 Dodge Ram Charger
Default Help!
i recently aquired a firing order diagram for my 1985 ramcharger. so i started pullin wires and puttin them where they were according to the diagram. However the first time i did this, the truck wouldnt start and while cranking it was popping. i believe it was dieseling. i could be wrong but anyways i got another diagram and this one showed all the wires shifted one in the clockwise direction. so i connected them that way and the truck now tries to start but after a couple cylinder fires it dies. it started before i did all this. is it possible that i screwed the engine when i believed it was deiseling? i didnt do it that much i didnt think but i dont know. any thoughts would be appreciated.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-16-2009, 02:13 AM
jeffs_62's Avatar
jeffs_62 jeffs_62 is offline
Vehicle: Power wagon
You have to make sure you are at Top Dead Center(TDC) before replacing your wires.
Pull out your #1 plug, put a finger tip in the hole and tap the starter little bits until it blows by your finger
After this, check your timing mark on the crank pulley, it should be pretty close to zero.
Now pull off your distributor cap, the plug that the rotor is pointing to is now number one, continue with your diagram in replacing your wires.
When this is done. it should fire and run.
Now get a timing light and time it.
If you don't have a haynes or chiltons manual for your specific vehicle, get one. Follow the procedure for timing and you should be good.
On a side note, the picture you a acquired for the firing order is for reference on which direction the rotor is turning and the subsequent order they fire in, it does not represent where the wires are supposed to be in relation to the front of the motor or the vaccum diaphram, if it has one.
Wherever the rotor is pointed at TDC is the #1 cylinder wire.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
