Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Power door lock problem
Old 01-18-2015, 04:07 PM
J.W. COWAN's Avatar
J.W. COWAN
J.W. COWAN is offline
Red face Power door lock problem
I have a 1985 Dodge Ram charger. My power door locks are locking and unlocking by itself. I need to know if I can pull the fuse and temporarily disable it until I can fix it. And if it is control by a fuse which one control it. Also can anyone tell me what is causing this problem. I looked at the fuse block but did not see a fuse labeled power locks. Will this drain the battery if I do nothing
Old 01-19-2015, 12:53 PM
jkeaton is offline
Dodge Forum Administrator
Sounds like a short in the wiring or a switch somewhere. Yes you can pull the fuse and just use the key to lock/unlock the doors until you find out whats wrong. Time to get some wiring diagrams and start tracing wires.
Quick Reply: Power door lock problem
