It is time.... Time to vote for Dodge Forum COTY! The entries are all the winners who are still active on DF (logged in within 30 days) from this past year.
NOTE: New members of less than 60 days will be unable to vote
The awesome entries are.....
Click the members name above their pic to view garage and additional pics.
In Car Entertainment:
TV in glovebox,two TV's in trunk,PS2,Alpine head unit,2 Crossfire 1000d amps,powering Orion HCCA 10",1 crossfire 4X75 powering mids/highs,Focal Utopia components up front Eclipse 6X9's in rear
Performance:
- Mopar Stage 3 FP Green Turbo
- 3" Mandrel Bent Custom Made Side Exit Exhaust System 'Cuda Style
- CTI 3" Oxygen Sensor Housing
- CTI 2.5" Charge Pipe w/Hemi Orange Powdercoating
- Mopar Stage 1 Computer
- Mopar Short Throw Shifter with Mopar Viper STS Shift Knob
- Mopar 7.5mm Spark Plug Wires with NGK 4306 plugs
- Mopar Stage 2 Wastegate
- Perrin Silicone Short Ram Intake System
- Crane .0014 cams
- Unorthodox Racing Cam gears
- MPX 62mm Throttle Body and spacer
- AGP Cold and Hot side Pipes w/T-Bolt Clamps
- HKS SSQ BOV
- TKMS CT-14 Oil pump and gears
- Gates Performance Timing Belt
- DCR Billet Timing Tensioner
- AGP Oil Accumulator
- AGP Aluminum Coolant Overflow tank
Tuning:
-DiabloSport Predator
- AEM UEGO Wideband
- Prosport Fuel Pressure gauge
- Prosport Exhaust Gas Temperature gauge
- Prosport Oil Pressure gauge
- Aeroforce Interceptor Scangauge
- VEI Systems Digital LED Boost gauge
- Greddy Profec –B Spec II Electronic Boost Controller
-Tip Sensor lines removed
Sounds:
-Jensen 7" In-Dash DVD Player
- Factory Kicker System
- XM Radio
Lighting:
-4300k H7 HID Kit for Retrofit
- 3000k H3 HID Kit for Foglights
- Valeo H7 HID Retrofitted Custom made headlights
- Projector foglamps with white halo ring
- Varad White Underbody LED kit
-Foglights converted into Running lights
Interior:
-Custom made Black leather/Pink piped Armrest
-Custom made Black leather/Pink piped Shift boot
-SRT-4 Embroidered into seats
- Viper ACR Harness pass-throughs
- Dash matched A/B/C Pillars
- Triple Pillar Pod
- Black dyed Headliner and visors
- Panther Pink Accents: HVAC, CD Bezel, Instrument cluster bezel, Seatbelt Anchors and covers
- Mopar door entry guards
- Cool White/Blue LED Intstrument Panel Lighting/HVAC Lighting/Odometer Lighting
- Warm White/Pink cupholder lighting
- Oznium.com Pink LED Rocker switches
- Fire extinguisher painted Panther Pink
- Custom Re-Upholstered trunk including:
Rear deck re-upholstered in black, tether strap covers and holes deleted
Back of backseat's re-upholstered in black
Entire trunk carpet done in black
Spare tire cover done in black with pink binding
Decklid carpet done in black with Pink Embroidery, center built up with foam to delete the contour.
Cargo mat with rubber backing (factory floor mat backing), embroidery, and pink binding.
Kicker sub trim ring painted Panther Pink
Suspension/Handling/Brakes
- Mopar S1 Lowering Springs
- ATE DOT 4 Super Blue Racing fluid
- Mopar Rear Tension Struts
- Mopar Stage 1 Front and Rear Rotors Cadium Coated, In Black with Hawk Carbon Fiber Pads
- Boomba Rotor Covers in Polished Natural finish
- Mopar Performance Adjustable Rear Control Arms
- Energy Suspension Full Black Hyperflex Bushing Kit in Black
- Mopar Performance Camber Bolt Kits Front/Rear
- Mopar Performance Steel Front Strut Tower Brace powdercoated Semi gloss black
- Mopar Performance Steel Rear Strut Tower Brace powdercoated Semi gloss black
Miscellaneous:
- Cobra Radar Detector
- Custom made "AAR" front emblem
- "Cuda'" rear emblem
Cooling/Injection:
-DEI Cry02 Intercooler sprayer
-JMB Radiator hardpipe PC'd Hemi orange
-Perrin upper/lower radiator pipes
-Koyo Performance Race Aluminum Radiator
-180 Degree Stant Thermostat w/Fan Switched on at all times
Engine Dress-Up/Misc. Engine Parts:
- AGP Solid Upper and Lower Motor Mounts
- Crankcase Breather
- Flat Black/Silver Injector Cover
- Hemi Orange Powdercoating:
Valve Cover
Intake Manifold
Throttle Body Spacer
Motor Mount/Motor Mount Block
Upper/Lower Thermostat Housings
- GG Coilpack Heatshield painted Flat Black
- Flat Black Exhaust Manifold heat shield
- Viper SRT-10 Oil cap
- Billet "Mopar" Coolant Cap
- JMB Aluminum "SRT-4" Radiator Gap Cover
- Hood Hinges Powdercoated Flat Black
- JMB Transmission Cover Powdercoated Flat Black
- Stainless Steel Polished Timing Belt Cover
- Stainless Steel Washer Fluid Cap Cover
- Stainless Steel Coolant Overflow Resivor Cap Cover
- Stainless Steel Oil Dipstick handle cover
- JMB Performance Brushed Aluminum Fuse Box Cover
- JMB Performance Polished Radiator brackets
- Factory Oil pan Powdercoated Semi Gloss black
__________________
If you're going to f*** up anyway,you might as well f*** up in such a way that it leaves people wondering how in the f*** did you do that??!!
1987 Aries coupe (1 of 926 surviving 87 coupes)/1984 Chrysler 5th Ave. (Down but not out??!!)
I thought the truck voting was hard, I'll have to come back to this, I'm torn between about 4 cars right now lol.
__________________ As a DF moderator My opinion is only my own and does not represent the DF community, it's staff, or affiliates. I moderate solely based upon guidelines and not in regards to my own personal beliefs. Rear Wiper Club Member #2
Quote:
Originally Posted by PappiDread6
Hello My Name is Pappi Dread and I have an addiction, Male DF Members
