1st Gen Intrepid 1993 through 1997 Intrepids
A/C help
Old May 27, 2007 | 03:13 PM
Buzzquest41's Avatar
Buzzquest41
Default A/C help
I just got a 97 Intrepid. I have a question about my air conditioner. It blows cool until the fans kick on, then blows warm. It's charged, and when the fans kick on, my gauge goes to 45 to 65psi, which indicates an overcharge. But when the fans aren't on, my gauge is in the normal psi range. Could this be a sensor problem? Any help is much appreciated. Thanks in advance.
Old May 31, 2007 | 02:01 PM
kurts2's Avatar
kurts2
Default RE: A/C help
By "fans kick on", do you mean the engine fan (on the evap side)? If so, is the air flow going the correct way (drawing air into the engine)? Also some more info please i.e. the temp outside, the temp out of the duct (both when the psi is 45 and 65), ect
Old May 31, 2007 | 03:52 PM
Buzzquest41
Yes. The engine fans. (Radiator). I can check to see if they are blowing the correct way. They should. I don't have any overheating problems. I'm in Tucson where it's in the high 90's. Coming out of the ducts, the air (when first turned on) is cool. It acts normal, getting colder as the unit is on. But when the radiator fans come on, thats when my gauge goes into the higher psi and warm air comes out of the ducts. When the fans go off, cooler air starts to flow again and the psi goes back to the normal operating range. I've also checked for error codes and found none. Which is what makes me question if there is an a/c temp sensor on this car.
Old Jun 2, 2007 | 01:17 PM
kurts2's Avatar
kurts2
Is the compressor kicking off when the fans come on (you should be able to visually check it)? Is this an after-market system, or factory? If factory, do you have the ATC (automatic climate control) or manual control? You can tell by if you have the digital temp readout on the control panel or the 3 large ***** and two buttons for the manual system.
Another thought, while I was looking at the compressor discharge pressure graph for this system, I see 45-65 range is ok if the liquid line temp is 40 deg, if it is hotter, you are probably undercharged. What is the temp of the line? Also what are you high side readings?
PS There are sensors on this car such as the sun sensor, the ambient sensor, (uses the battery temp sensor as a back up if this is failing), and the ATC in-car sensor (if you have the ATC)
Old Jun 3, 2007 | 05:25 AM
Buzzquest41
No. The compressor stays on when the fans start running. The air was constantly warm this time. The fans were constantly running too. The pressure bounces from 45psi to 70psi. When my gauge reaches 70psi, it "kicks down" to 45psi. Then the gauge goes non stop back up to 70psi. When the engine is off, I hooked up the gauge and it reads a little above 70psi. (Don't know if that means anything) How and where can I check the liquid line temperature? I don't have a gauge that fits the "high" side/port. I'm doing my checking on the "low" side/port of the compressor. The car doesn't have the ATC sensor. That's the one on the top of the dash, right? There is no sensor on my dash. Where are the other two sensores located?
Old Jun 4, 2007 | 06:56 AM
kurts2's Avatar
kurts2
To check the liquid line temp, a "thermocouple probe" is used. It looks like a battery alligator type clamp used on small accessories that hook up to the battery (not as large as a jumper cable size). You could usea laser thermometer or even a meat thermometer held on with tie straps if you don't have one, it’s better than nothing. Attach/check the temp probe as close to the condenser outlet as possible. The line is the smaller line below and between the compressor and the air filter box.
The ATC sensor is either behind the small Chrysler emblem above the glove box or in the control head in some models. The sensor that sits top and center of the dash that looks like a small red plastic speed bump is the sun sensor. The ambient temp sensor is located on the inside of the front bumper (left side). It has one bolt, one electrical connector (on the top) and a “nipple†at the bottom of the sensor. The best way to test the system is with the expensive Chrysler testing equipment, but there are self tests that can be run through the car. You still have to let me know which system you have first, the manual control head or the auto (see prior post).
To help prevent the PSI from bouncing too much, try blocking off the airflow to the front grill area; it will help maintain a constant pressure by stopping the cooling fans from switching from high and low speeds.
Old Jun 4, 2007 | 06:48 PM
Buzzquest41
I'm sorry. I have the manual controls. Can I buy a "Thermocouple Probe" at a local parts store? Is that the correct name? I'll search for and check on the other sensors. I'll check back later and see if you posted anything new or know of any tests I can do myself. Thanks.
Old Jun 7, 2007 | 03:15 PM
kurts2's Avatar
kurts2
Sorry, my bad, you said prior that you didn't have the "high guage". The liquid temp chart is for the high side so the probe will be of no use to you. Looking back on all you said it sounds like the system is "short cycling". Are you sure the comprosser isn't kicking off? If so, you may just be a can low. There is a check for the manual system components, thats why I wanted you to let me know as the procedures are completly diffrent.
To place the head in dig mode,
1. Start engine, the engine must be running for the entire test...do not move car.
2. Place the left **** (fan speed) to any except off.
3. Place center **** (temp) to full cool.
4. Place the right **** in defrost mode.
5. The AC button is ok on or off possition.
6. Press and hold the rear window defogger switch for 3 to 5 sec. The rear defog lamp will begin to flash, release the button when it begins to flash. The system is now in dig mode. If you wish to abort, turn the fan to off, move either of the other two ***** or press the AC or rear defog switch once.
7. The light should flash for about 30 sec and go out. The next procedure depends if the light goes out or comes on steady. Let me know.
Old Jun 10, 2007 | 07:33 PM
Buzzquest41
OK. I did what you said. The system cycled through from defrost to floor to face. All hot air. After about 30 seconds the rear defrost light stopped flashing and went out. I checked the "Low/side" pressure and it topped at about 108psi, then went down to about 75psi. The rpm's also jumped from 6k to about 12k the whole time. Constantly bouncing back and forth. I did notice the condensor came on only when the psi was falling. Once it stopped falling and started to rise, the condensor would stop running. Now I'm really lost!
Old Jun 11, 2007 | 02:48 PM
kurts2's Avatar
kurts2
By condensor, did you mean compressor? Also I hope you ment 600-1200 RPM, not 6000-12000!!! First tell me, did you try to add a can? So far as the test is concerned, the control head has been checked, and a cal has been done on the system. The next part involves a lengthy procedure and before I type it out, I'd like to ensure you have charged the system asit sounds like it's short cyc. Not only, but the next test checks every little detent possition of your *****, and from your problem I don't think that will be of much use.
