Neon SRT-4 Dodge Neon SRT-4 is the pocket rocket that took the import scene and turned it upside down.
Uncooperative 2nd gear
Old Nov 19, 2007 | 10:05 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default Uncooperative 2nd gear
Looking for some input before going to the stealership. 2nd gear has been a little 'rough' to shift into. both upshifting and downshifting. its rather obvious that it dosent like to go into that gear as much as the others and colder weather makes it more prevelant. you gotta 'push' on the shifter a little more as it goes into gear. Yes, the fluid has been changed in the last 1k and it hasnt helped 2nd out. (I change the fluid every 15k). Im thinking its the synchros, in fact, almost certain that is all it could be. and with 31k on the clock I want to get it taken care of soon.
anything else I could consider before taking it in?
anything they may bitch/gripe about with my mods or the fact I change my own fluids?
thanks yall
Old Nov 19, 2007 | 10:16 AM
PSI Chick's Avatar
PSI Chick
Default RE: Uncooperative 2nd gear
they'll bitch that you own the car lol.
Old Nov 19, 2007 | 10:27 AM
flamingpinhead
Section Moderator
ORIGINAL: PSI Chick
very true. wonder if they will look at the occ and ask "whats that for?"
Old Nov 19, 2007 | 11:34 AM
Burnnout's Avatar
Burnnout
They will probably just push you out the door with "no fault found".
Old Nov 20, 2007 | 12:26 AM
flamingpinhead
Section Moderator
^like when my TPS was having issues... it tookseveral trips to the dealership before it was fixed right[:@]
trip 1: replaced plugs/wires (speaking of which, i should check on them soon) -also advised them of reading about the TPS issue on the forums and how it seemed like that was the problem. picked up the car and at the first redlight a mile down the road... it was reving itself up
trip 2: replaced TPS - went to pick up the car and it started f***ing up in the parking lot of the service dept. i took the keys right back inside... "i thought you said it was fixed?" they didn thave time/parts to fix it again. oh, an no loaner cars here buddy
trip 3: replaced TPS wiring / harness. finally... i picked up the car and it actually ran right
cant wait to deal with them on the transmission... im going to lose my mind if they call and say there is nothing wrong with it. 'so, if i take it to Dasher's garage right down the road, and they fix my transmission... are you guys gonna cover the bill under warranty? seeing as your too incompetent to fix it?'
ahhh..... breathe in, breathe out
sorry, but i hate going to the dealer
Old Nov 20, 2007 | 01:20 PM
Burnnout's Avatar
Burnnout
hahaha... dealer's are good for a lot of things, but major problems under warranty aren't what they make money on. They were ignorant about the tps issue..... that's why things like that even under warranty I do myself. Depending on what type of warranty it is, some independant shops can work with them.
Old Nov 20, 2007 | 02:27 PM
flamingpinhead
Section Moderator
yeah, its just aggravating when you know what the problem is, you want them to fix it... but they hem and haul around, not wanting to listen, just doing their own thing.
just called... oh lord i need to find reciepts for my trans fluid. GEEZE
Old Nov 20, 2007 | 02:34 PM
Burnnout's Avatar
Burnnout
lol have funwith that.... .good luck btw.
Old Nov 20, 2007 | 02:42 PM
flamingpinhead
Section Moderator
well, at least the Trans fluid... i bought at the dealership (i bought enough for 2 or 3 changes)
Old Dec 1, 2007 | 01:17 PM
XXL 1500's Avatar
XXL 1500
try and remove any obvious aftermarket engine upgrades before trying to go and get them to drop the tranny.
i had to turn one down for a guy having Nitrous in the car... still hooked up and valve open...
complained of a clutch slipping... well durr if you are pushing out like 500HP
