check engine light blinks 10times
Old 09-26-2012, 07:44 PM
psarno109's Avatar
psarno109
psarno109 is offline
Default check engine light blinks 10times
my check engine light is blinking 10x in a steady pattern. there are no pauses in between the blinks. what does this mean?
Posted from Dodgeforum.com App for Android
Old 09-26-2012, 09:07 PM
caoe74's Avatar
caoe74
caoe74 is offline
Does it happen when you turn the key without starting the engine?
Have you disconnected the battery recently or cleared existent codes? If yes then what happens is that the ECM is not done going through the diagnostics cycle. Once it's done the blinking will go away. Hope this helps.
Old 09-26-2012, 09:33 PM
psarno109's Avatar
psarno109
yes I disconnected the battery today to perform a reset because I am getting very bad vibrations in the low rpms. I just replaced the oil pressure switch and that's when the vibrations started. have any idea what could be causing the vibrations
psarno109's Avatar
psarno109
Old 09-27-2012, 06:02 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Yes to which question?
Old 09-27-2012, 06:33 AM
psarno109's Avatar
psarno109
yes to it only happens when the key is in the on position but not started
Old 09-28-2012, 02:21 AM
darthroush's Avatar
darthroush
Section Moderator
If it's not flashing while the car is running, it's probably what caoe74 said. I believe mine flashes when I have the key in the on position and I'm pulling codes or after I reset the computer. If it starts flashing while you're driving, well, that's a whole 'nother thing.
Old 12-25-2012, 08:53 PM
mike L's Avatar
mike L
mike L is offline
Default 10 blinks normal?
Hi, My 05 neon also blinks 10 times, after clearing a PO302 miss fire code. I'm sure the 302 code will come back on, in a few days. So it's normal for all 2005 Neons, to do the 10 blinks?
Old 12-25-2012, 09:45 PM
caoe74's Avatar
caoe74
caoe74 is offline
Yes! Until it finishes it's diagnosis cycle the ECM will flash the CEL 10 times with the ignition in the ON position to let you know.
MetricMotors (02-05-2022)
Old 12-25-2012, 11:07 PM
fhadso's Avatar
fhadso
fhadso is offline
Mine doesn't blink, but stays on until I start it.
Quick Reply: check engine light blinks 10times
