Heeeeelllppppp!!!!!!
Old 04-01-2013, 11:32 PM
0867LCumminsXXX's Avatar
0867LCumminsXXX
0867LCumminsXXX is offline
Default Heeeeelllppppp!!!!!!
OK so earlier today i posted charging issue.... welll.... I cleaned and replaced every battery cable i could.... the alt started working again.... for about 10 min of driving then i turned it off parked it at the store.... started it back up and it was not charging once again.... now i got the truck home put it on my flash pak tuner and got 16 dtc....
P0405) exhaust gas RE-CIRC sens Low
P0603) Internal Control Module (CAM) error
P0487) EGR Throttle POS CTRL CIRC
P245C) EGR Cooler Bypass CNTRL CIRC LOW
P2609) Intake air hearter system performance
P000F) Fuel System over pressure Relief valve Activated
P1012) MPA CIRC LOW
P113C) O2 Sens power supply Perfomance
C2100)Bat Voltage LOW
C2202) Original VIN Mismatch /MISSING
C2206) Vehicle Config Mismatch
U0141) LOST COMM With BODY CTRL MOD A
U0100) LOST COMM With ECM/PCM A
P127E) Fuel Pump CTRL CIRC 2 OPEN (TIPM)
B2100) Ignition Run/Start INPUT CIRC PERFORMANCE
B165E) Park lamp CIRC CTRL OPEN
I have the EFI tuner on the way for the dpf delete codes and the egr but the others I HAVE NO CLUE ABOUT!!!!!
I need to reflash the comp to the stock settings from the flashpak to the EFI tuner but is it safe to do so ? I am at a total loss here?>
I did the EGR delete from Sinister diesel and all these problems arrised I cleaned the corrosion of the terminals the same day the altinater passed the load test and so did the batteries.... im at a loss
Old 04-09-2013, 04:44 PM
Uncle Meanie's Avatar
Uncle Meanie
Uncle Meanie is offline
I would start looking at your grounding circuit. Check the connections to the body, engine, and frame to see if something is loose.
That is a lot of codes to pop up at one time.
Old 04-09-2013, 05:49 PM
aofarrell2's Avatar
aofarrell2
aofarrell2 is offline
^ +1. No grease on the grounds AT ALL.
Old 11-30-2016, 11:20 PM
bugggs's Avatar
bugggs
bugggs is offline
DID U EVER FIGURE THIS PROBLEM OUT? I HAVE THE SAME ORDEAL BUT GAS ENGINE SAME CODES AFTER REPLACING MY PLUGS WILL NOT PASS EMMISIONINS c2202
C2202) Original VIN Mismatch /MISSING / U0141) LOST COMM With BODY CTRL MOD A / U0100) LOST COMM With ECM/PCM A
Old 12-02-2016, 02:10 PM
Asmug's Avatar
Asmug
Asmug is offline
also interesting!
Old 12-02-2016, 05:22 PM
p38251's Avatar
p38251
p38251 is offline
I know this thread is old. However load testing a battery may or may not tell you battery is good or bad. Example. My truck 2012 ram 6.7. Truck dead after sitting 2 days. Both batteries load tested good. Went up North. 30deg that night, next day dead. My point is OEM batteries that are over 4 yrs old are on borrowed time. Sounds like new batteries could solve this issue.
