Fuel pump not starting
I've got a 1995 1500 with the 5.9 LDC motor. It hasn't run well since I bought it, but now it won't even start. Here's what I know so far:
I've tested both the ASD and Fuel Pump relays and they are fine. I've jumpered around the pump relay and can definitely hear the pump running. Using a meter I can see the PCM never grounds the control wire running to these relays.
I don't know the next steps to diagnose this?
Originally the contacts on the PCM connector were corroded, probably because the weatherstripping foam above it fell off a long time ago. I've tried a couple times clean the contacts. Back when it was running the check engine light flashed the code for the EGR valve, but now the check engine light doesn't come on at all.
Thanks in advance,
Chuck
Thanks in advance,
Chuck
Here's the link I've seen, gots the codes on it too.
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Cant you just turn the key on and off 3 times, and it will flash the codes? It's what I've been doing. Or are you shorting the terminals to override since the pcm is possibly dead?
I got a reconditioned PCM and am getting ready to try it out. Since this is a 1995, is there anything I need to do to re-learn any of the engine settings like the throttle position?
Also, can someone point me to where the "factory splices" are in the wiring? I've seen mention of it, but am not sure of their exact location.
TIA
TIA
Swap PCM's with the battery disconnected. Once everything is in place, hook the battery back up, turn the ignition to "on", not start... don't touch ANYTHING, count to ten, start the motor. PCM will re-initialized its various sensors/controls, and then it just needs to learn the engine. All ya gotta do is drive it.
There are a LOT of factory splices. They are all listed in the service manual, at the end of the electrical section.
Usually a connector, sometimes, a ring terminal with a lot of wires going to it. (generally for the ground side of a circuit) There are also occasions where they just use the cheap 'fold over' splices. Those suck, and are pretty much guaranteed to fail... (and is why the trailer harnesses sometimes have issues....)
