Which torque converter
Old 11-29-2016, 10:00 PM
97ramrod1500's Avatar
97ramrod1500
97ramrod1500 is offline
Default Which torque converter
I've got a 46rh in that I will be rebuilding shortly. It seems when it comes to torque converters there are 2 options: lock-up or non lock-up.
How do I determine which converter I need to get to replace the old one? I do have the old one but haven't looked at it yet.
Old 11-30-2016, 06:56 AM
Moparite's Avatar
Moparite
Moparite is offline
Is this for your truck? If so it should be a 46RE "E" designates electronic where the "H" means hydraulic.
Old 11-30-2016, 07:38 AM
PJ97Ram's Avatar
PJ97Ram
PJ97Ram is offline
Stock has a lockup TC
Old 11-30-2016, 08:18 AM
97ramrod1500
Not for my truck, its for a 1994. Has the 46rh in it.
Old 11-30-2016, 08:56 AM
They all had locking torque converters from the factory.
Old 11-30-2016, 09:00 AM
97ramrod1500
Alright cool. Why is a non lockup converter even an option then?
Old 11-30-2016, 09:01 AM
That is a very good question, and one that I don't really have an answer for. Maybe for the racing/off-roading crowd? Personally, I don't see any reason at all to use a non-locking t/c.......
Old 11-30-2016, 09:42 AM
97ramrod1500
Ok. I just wasn't sure since the plug on the outside of the case is only a 3 pin connector. Must be for the lock up solenoid? Is there no governor pressure solenoid or sensor?
As you can tell I haven't had a chance to pull the trans apart yet.
Old 11-30-2016, 10:07 AM
The RH transmissions are all hydraulically controlled for the first three gears. Your three wires are one power, and then two grounds (going to the PCM) for the TCC, and O/D solenoids. It's a dead simple system, and seems to work fairly well.
They went to electronically controlled in 96, with the change to OBDII. Then you get five more wires for the governor stuff.
Old 11-30-2016, 12:59 PM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
The first 2 minutes of this video answers this question.
Dave
