Catalytic converter, change or leave alone? 230k miles
Old 12-04-2016, 04:35 PM
Bigpoppa99's Avatar
Bigpoppa99
Bigpoppa99 is offline
Default Catalytic converter, change or leave alone? 230k miles
Just got my 02' Ram 1500 5.9 back from a complete remanufactured motor job. The guy that done my motor suggested as a precautionary thing to get a new catalytic converter put on since the truck has 230k miles on it. He said that a bad or stopped up catalytic converter will make the motor run hotter than it suppose to thus causing harm to my motor. Well I took it to my local muffler shop and they suggested I wait until my truck throws a light and that the truck will have a sensor saying that the cat is bad. The price on a new cat I priced there is $310 installed. Although that is alot of money I wouldn't mind spending it only if I absolutely needed to.
My question is, what to do? Should I go ahead and change the cat regardless or wait til my truck throws a light then get one put on? Or does these things throw a light well PAST the time it needed to be changed?
Just dumped $2600 in a complete engine rebuild and it's running great and I don't want to jeopardize this motor in any way.
Please note this truck had a Flow master exhaust installed prior to me buying the truck, it has 1 catalytic converter, then goes back into the flow master then splits into dual exhaust from the flowmaster back
Old 12-04-2016, 05:44 PM
p38251's Avatar
p38251
p38251 is offline
IMO I would leave it.
Old 12-05-2016, 09:42 AM
ocdropzone's Avatar
ocdropzone
ocdropzone is offline
I would only worry about it if you have to pass emissions.
I have to go through emissions testing every two years in the Portland Metro area.
I failed with an old truck a few years ago, installed a new cat. Passed with flying colors
Old 12-05-2016, 02:50 PM
primem's Avatar
primem
primem is offline
there is no cel dtc for restricted cat only cat efficiency. the cats could be restricted and not set a dtc.
if the cats restricted you would have lack of power and bogging on snap throttle. If you have no symptoms forgettabout it.
if its that much of a concern you could have the backpressure of the exhaust measured.
