Muffler keeps blowing baffles
I have a 07 Dodge Ram 1500 hemi 4x4. Back In June we had a lot of rain and I was parked in a low area and caused water to get into my engine. Insurance covered it and replaced it with a used engine out of a 08 ram 1500. After motor swap ive had had issues none stop. Now, I have horrible fuel mileage and with it running like crap I have no check engine light. EGR valve went bad and didn't throw a code, was a tapping sound like a lifter. Got that fixed and now I keep blowing my mufflers up. Not exploding but blowing the baffles up. I had a flow aster at first and the muffler shop replaced with another flow master and about a week later it blew the new muffler. I'm now using a cheap muffler because I cant afford to keep buying mufflers. but I'm still the same boat. this one has been on for 2 days and already blew up. someone please help!!!
See Hemi engines breathe like a mother F*ck, and when you put the pedal down they will trash mufflers. I gave up on mufflers, for one they always blow out and two it sounds like God himself kicking the devils *** and its so sweet, I get compliments all the time on the sound, and the truck made itself sound that way.
My truck had a brand new muffler when I bought it from my friend February 24th of 2014, by April of '14 I had just the manifolds, cats & Y pipe left because the muffler pretty much exploded. Also by April I was on my second set of rear tires.
My friend had at least 5 mufflers on it when he owned it. Always blew them out.
Where are the pics of said blown up muffler/s? flowmaster makes a lot of different mufflers. The model used also would be helpful.
http://www.autoanything.com/exhausts...mparison-guide
You probably don't pound the hell out of it like I do. My buddy was an EMT/First Responder and my truck never had it easy in his or my care. My brothers hemi Durango muffler is starting to get louder, he's had it two years.
If cats were plugged the muffler wouldn't be blowing up...less pressure.
The stock muffler is not up to the long term task for an enthusiast who pounds on their vehicle all the time, there are better quality mufflers out there up to the task but I really don't know what too many of those would be as I don't believe in mufflers on a Hemi.
Why not just buy a facory exhaust set-up from one of these guys that took theirs off? Or go to the junk yard and cut one off. I am still running my factory resonator and muffler and believe me it flows and sounds very good.
I have no problem showing these new hemi's that the first ones are real screamers and nothing to underestimate! Had a new one the other day challenge me and when he heard and saw me going around him his jaw dropped.
I admit that my exhaust has opened up over the last few years but personally having a stainless steel exhaust that was designed for my motor and performs as well as it does without modifications other than changing out my Y a few years ago is really the way to go unless you have some serious engine mods that require more exhaust. From what I have learned about the Hemi over the years I have had it is it needs a certain amount of back-pressure and having a wide open exhaust may not have a positive effect on performance.
just my 2 cents
OEM off-road 17's, BFG LT's, Airraid CAI, Cortex 3950, Magnaflow Y, Detroit TT, Mag Hytec trans and rear, SRT A-pillar w/ Autometer trans temp., 190 T-stat, Pwr stop drilled/slot all 4, Power wire, Grnd T-body
just my 2 cents
