2010 Dodge Ram Shuts off when braking
Truck shuts off when braking or making sharp turn
Do you brake with your left foot instead of releasing the accelerator and braking with your right foot? May sound like a stupid question, but if you brake while your foot is still on the accelerator, it may be that you are still depressing the accelerator enough to cause the engine to detect a fault which will automatically kill the engine. This is easy to do while making a sharp turn also. It could be that your brake pedal sensor that controls this process is defective, I just had to have mine replaced because of this. You might verify this by checking to see if this sensor has reported a fault code which might not show with the light.
