4.7L Knocking Noise
4.7L Knocking Noise
Hello, this is my first post. Thanks for having me.
I purchased a 2002 Durango with the 4.7L late last week with a knocking noise. I assumed it was a hydraulic adjuster...and was wrong.
The vehicle has 98,000 miles on it with no sign of oil in coolant or coolant in oil.
My observations on the noise:
1. Sounds like it's coming from the passenger cylinder head.
2. Gets faster with more engine speed.
3. Knocks 90% of the time, but occasionally will cease or soften for a few seconds.
4. Makes the noise whether engine is cold or at operating temp.
5. Stops momentarily when I let off the gas and let the engine speed fall to idle from a mid range rpm. Resumes at normal idle rpm. (Guessing it stops because of reduced load)
My plan moving forward is to start the engine and unplug one coil at a time from that bank to see if I can make the noise almost go away. If I can, I'll swap a couple coils around to see if I can move the noise. Assuming that fails, I'll be dropping the oil pan and doing some rod wiggling to see if I can find a loose wrist pin.
My best guess is that it's a wrist pin based on where the noise is coming from, but I believe it's rare that those go bad. Not even sure how they would go bad. What causes that?
What are y'alls thoughts on this?
Video:
Video:
