Blower motor for heat wont turn on at all
Old 01-14-2017, 03:34 PM
1998ram5.9's Avatar
1998ram5.9
1998ram5.9 is offline
Default Blower motor for heat wont turn on at all
I'm trying to pinpoint the problem but before I go any farther I figured I'd ask first. I've changed the blower motor resistor, bench tested the blowerror motor it's self and wired a new plug that plugs into the resistor and still no fan speed what so ever when I'm turning the heat on in the truck. Any ideas? Thanks
Old 01-14-2017, 03:57 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Checked the fuse yet?
Or the relay?
Old 01-14-2017, 05:30 PM
1998ram5.9's Avatar
1998ram5.9
Or the relay?
well.. this is this first time in my life the fuse was not pushed in all the way for what ever reason. Can't believe I didn't check it, automatically thought the worst haha thanks man.
Old 01-14-2017, 05:54 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Funny you should mention that...
I have a certain fuse in that little panel that doesn't like to stay in either. I had to give the prongs such-an-ever-so-slight bend.
Old 01-14-2017, 07:39 PM
1998ram5.9's Avatar
1998ram5.9
yep, it was loose fitting, so I did the same thing, dodge life... haha
