[General]: Rubber Hose replacement to power steering cooler
As it turns out, the parts house sold the incorrect hose to me...should have been a 3/8" hose.
On another note, I refilled the power steering reservoir, started the car let it run for 5 mins then shut it off. I began to notice the fluid coming through the cap of the reservoir!
Any thoughts????
Thanks
Any thoughts????
Thanks
hard to say without seeing what you have done.
maybe you should buy complete direct fit lines from the dealer instead of buying hose and splicing into the steel lines. its ok add hose into the low psi side return but the high side generates 600psi and needs high pressure crimped hoses and compression fittings.
