Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Journey pulls to one side - need some troubleshooting tips
Old 01-17-2017, 01:06 PM
thejourney's Avatar
thejourney
thejourney is offline
Exclamation Journey pulls to one side - need some troubleshooting tips
We purchased a brand new 2016 Dodge Journey FWD 4cyl about 9 months ago and noticed after driving it for a few months that it tends to pull to the left.
You can let go of the steering wheel and the journey just starts to drift immediately to the left, this is even when the road is sloped and doesn't matter what lane you are in. On long trips I get sore from having to hold the steering wheel firm to stay straight.
Today will be the 3rd time I bring it into the dealership and we are looking at a 4th time because this still isn't resolved.
We have done the following:
Visit:
1. Check alignment, make adjustment to the alignment and center steering wheel.
2. Swapped the left wheels to the right **** now pulls to the right
3. Check alignment, made adjustments. (today)
Now before the 3rd visit, we changed the tires from the 4 seasons to winter so we can rule out the tires.
I am at a complete and total loss, the service guy doesn't seem to think that this has to do with the wheels because if they were bent then we would feel a wobble or something like this.
I have no idea why swapping the wheels would make the vehicle pull to the other side, I am hopping that someone here has had this problem and offer a solution before I go into the dealer and waste another morning.
Thanks!
Old 01-17-2017, 01:12 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
If the pull moved then....well...
Old 01-17-2017, 01:27 PM
thejourney's Avatar
thejourney
My thinking exactly, but if the tires have changed and are balanced, can a rim really affect the pull like that?
Have you seen this before?
Should I ask them to change the rims?
Old 01-17-2017, 01:32 PM
TNtech's Avatar
TNtech
TNtech is offline
Tell them to move wheels from back to front. I'm not 100% positive that a wheel with runout will do much other than vibrate.
Did they take tires from another lot car? There could be a malformation on the part of the wheel that contacts the wheel hub.
Old 01-17-2017, 01:35 PM
thejourney's Avatar
thejourney
I will suggest they do the back to front, but these are new winter tires, the tires that were on the vehicle when we purchased are sitting in the garage.
Still worth the swap?
Thanks for your quick replies!
Old 01-17-2017, 02:20 PM
TNtech's Avatar
TNtech
TNtech is offline
If it's still pulling then don't re-swap them. It wouldn't do any good. Focus on that wheel for now.
Old 05-12-2017, 02:12 PM
30BR's Avatar
30BR
30BR is offline
If one of the wheels is out of spec on the wheel offset that could cause this.
Old 05-12-2017, 10:04 PM
primem's Avatar
primem
primem is offline
its not the rim, its the tire...you have a conical tire....its a defect in the tire ply construction or a broken belt in the tire. replace the tires. It common with old or cheap tires. a road force balance can measure the amount of pull a tire has and radial tire variation.
If you have a awd vehicle all the tires should be replaced so they all have the same circumference...mismatched tire circumference stresses the tcase or pto as the axles and differentials are turning at different speeds from tire mismatch.
Old 03-01-2018, 06:59 PM
Micheal Collins's Avatar
Micheal Collins
Micheal Collins is offline
Default Torque pull
im having the same issue. They say it’s torque pull. Still fighting it
Old 03-01-2018, 09:15 PM
TNtech's Avatar
TNtech
TNtech is offline
Torque pull, well...noticeable torque pull in a passenger car is not normal. Maybe in a truck with a trailer load on the back.
Alignment is past spec, an half shaft is bad or something is bent.
