Fuse help
Old 01-18-2017, 12:12 PM
wayne315's Avatar
wayne315
wayne315 is offline
Default Fuse help
2002 durango 4.7 ...which fuse controls the transfer case control module and where's the fuse box...thanks
Old 01-18-2017, 12:28 PM
jkeaton is offline
Should be in your owners manual.
Old 01-18-2017, 01:54 PM
wayne315's Avatar
wayne315
wayne315 is offline
The owners manual says "pop" the cover and look at the diagram" which I did and the TCCM is not mentioned on either the interior box or the one in the engine bay?
Old 01-18-2017, 02:39 PM
jkeaton is offline
It's probably labeled something else. Like 4x4
Old 01-21-2017, 04:29 PM
wayne315's Avatar
wayne315
wayne315 is offline
do you know if any code scanners help with check 4WD light
Old 01-21-2017, 06:54 PM
jkeaton is offline
Obd scanners only read obd codes.
Old 01-22-2017, 09:01 AM
JeeperDon's Avatar
JeeperDon
JeeperDon is offline
Wayne, start at the beginning. What's going on, what symptoms are you seeing?
Quick Reply: Fuse help
