2002 ram 1500 4x4 torque specs
Old 01-20-2017, 09:23 PM
shanes76's Avatar
shanes76
shanes76 is offline
Default 2002 ram 1500 4x4 torque specs
Anyone know the torque specs for the upper control arms to the frame
Old 01-20-2017, 11:06 PM
Greg in MO's Avatar
Greg in MO
Greg in MO is offline
Manual says 120 ft-lbs.
Old 01-21-2017, 06:48 AM
shanes76's Avatar
shanes76
shanes76 is offline
Ok thank you
Old 01-21-2017, 09:37 AM
Greg in MO's Avatar
Greg in MO
Correction. For 2002 it says 97 ft lbs. The 120 was for 2003. Not sure why it changed.
Apologies.
Old 01-21-2017, 09:57 AM
shanes76's Avatar
shanes76
shanes76 is offline
Ok, if the old bolts come out is it ok to reuse them or should I get new
Old 01-22-2017, 09:34 PM
Greg in MO's Avatar
Greg in MO
Assuming that they look ok (not corroded too much) I would reuse them. Those bolts aren't torqued to deformation like head bolts are. Might want to clean up the threads at least.
Old 01-23-2017, 04:17 AM
shanes76's Avatar
shanes76
shanes76 is offline
Ok, last time I had it aligned, the tech said he got it loose enough to get in align but was afraid of breaking it
Old 01-23-2017, 10:41 PM
Greg in MO's Avatar
Greg in MO
Hit it with PB Blaster several times and let it sit for awhile. Hopefully they will come out ok.
