[4th Gen : 01-07]: Accelerator pedal / code question
I have a 2003 Grand Caravan Anniversary Edition about 130000 miles on it. Driving down a mountain highway, my daughter experienced what she described as a 'loose at the top' pedal. The throttle operation seems to function normal from idle to full, but now has a 1" to 2" slop between the pedal linkage and the throttle control cable (the grommet appears to be there) and the pedal itself pivots about 45 degrees on the assembly. Using the ignition key method the P0633 code followed by done appeared. No code detected with my car md or innova 3100 readers. Could the code be old or is it possible the two are related?
Thanks in advance for any suggestions or help.
