Brakes b3500
Old 01-24-2017, 03:37 PM
braz's Avatar
braz
braz is offline
Default Brakes b3500
I HAVE REPLACED THE FRONT ROTORS(3) TIMES, CALIPERS, PADS ,BALL JOINTS, I/O TIE RODS, I CANT GET THE PASSENGER RIGHT FRONT FROM WARPING AFTER AROUND 500 MILES. REAR BRAKES,DRUMS REPLACE ADJUSTED.ANYONE ELSE HAVE THIS KIND OF ISSUE. b3500 96 5.9 82000
Old 01-24-2017, 05:18 PM
iodj44's Avatar
iodj44
iodj44 is offline
It is a understatement you have a problem, you probably should replace the front brake lines at least the rubber part that go to the calipers. Also the proportion(? spelling) valve or a ABS component may need to be adjusted or replaced but the fact only the passenger side warps it is unlikely a adjustment is in order. If you live in the northern part of the country everything is probably rusted and replacing questionable parts is not such a bad idea considering we are talking about brakes.
A guess is your pads are lightly dragging on the rotor and the heat is causing it to warp that is just my $.02.
Old 01-24-2017, 11:43 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Originally Posted by braz
i have replaced the front rotors(3) times, calipers, pads ,ball joints, i/o tie rods, i cant get the passenger right front from warping after around 500 miles.
The interior of brake hoses can deteriorate and cause the calipers to lock and the rotors to warp.
Old 01-25-2017, 02:11 PM
braz's Avatar
braz
braz is offline
Thanks for the information. I will see if new brake lines help. It has ABS on the rear and a 4000lb axle on the front. Like the van would like to keep it if I could just get these brakes fixed. These single puck calipers.......
Quick Reply: Brakes b3500
