Manifold Smoking, Cant remove?
Hey all, First time user on here, Normally I stick with my ford truck but my brother wanted a ram for his first truck. Having a bit of trouble though so hoping someone can help...
Its a 97 ram 2500 5.9L heavy duty. Got it for a really good deal but the passenger manifold starts smoking really bad after 2-3 minutes, It seems as there is some type of oil/grease or chemical all over the manifold thats causing it to smoke. I tried removing it to wire wheel all the rust and junk off but the manifold is really stuck. the 2 end bolts on each side came off no problem but the 2 center bolts snapped off where the bolt head and washer meet. I had to heat up the stud and washer to break the rust weld from the stud. The two studs in the center that broke at the bolt head are still in but all smooth which shouldnt keep holding the manifold to the engine. Are there any tricks on getting this manifold to come loose so I can either wire wheel it or most likely just replace it? Cant drive it with it smoking as it gets pretty bad the longer it runs. ( Im also sure its not a head gasket issue or oil leaking from the valve cover )
Thanks.
Thanks.
All that crap has to be coming from somewhere..... Did someone fix the valve cover gasket before you got it?
To get the manifold off, you also need to remove the bolts from the y-pipe to manifold. Might even have to do both sides, so it will drop out of the way... then the manifold should just pull right off.
Welcome to DF!
Welcome to DF!
Welcome to DF!
Welcome to DF!
Thanks
That's what I figured. It's not drivable in the current state so if replacing it is needed then that's fine. Hot wrenching would be difficult as I don't have a acy torch, only a map / oxy torch which probably wouldn't cut it, guess I'll break out a bfh and see what happens. Thanks
access is no issue. Truck is sitting on 33" tires so I've got plenty of room, I tried shoving a pipe in the bottom of the collector where the manifold meets the y pipe and prying but no budge, maybe a bit of heat and a 2x4 will help
