Do rear windows lock?
Post moved and thread created for you.
They are only motorized. I don't remember or seeing a way they can lock. If you can manually slide the window, then the cable has broken inside the motor and themotor will need to be replaced. You will need to remove the rear seat back to change the motor. I don't think they are very expensive. $100 or so.
