Tranny Over temp light came on
Old 02-21-2017, 07:58 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
Default Tranny Over temp light came on
Hi all
Out of the blue the red tranny over temp light came on, so I checked the fluid level which was on the low side. Topped it up with fluid. Drove a little while, the light flickered and then came back on permanently again.
Any ideas would be appreciated
Many Thanks
2004 SLT 4.7L 205000 miles
Old 02-21-2017, 09:25 PM
jkeaton is offline
Since you don't mention service history, I'd try dropping the pan, change the filters and refill.
Old 02-22-2017, 07:53 AM
Gorhad's Avatar
Gorhad
Gorhad is offline
OK thanks for the advice. Ive read also it could be a PCM going bad, is that a possibility too?
Old 02-22-2017, 08:52 AM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
How about your coolant level and condition?
Old 02-22-2017, 08:09 PM
p38251's Avatar
p38251
p38251 is offline
Does the trans fluid smell burnt. A slipping trans makes heat. Could simply be a bad sensor.
Old 02-23-2017, 03:34 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
No not burnt or slipping, Gear change is nice and smooth and a good change up and down and the color is nice and reddish. It went off all day yesterday then today i get in it start it up and the lights on again
Old 02-25-2017, 08:46 PM
66three83's Avatar
66three83
66three83 is offline
Well, if it came on with a cold start, it's obviously not overheated. I would find the location of the sensor and replace it.
Old 02-26-2017, 01:35 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
Thanks 66three83
And thanks everyone for your help and advice
