Synthetic Motor Oil
Synthetic Motor Oil
It's almost time for my first oil change since my new engine was built. I've always used Mobile 1 when I needed a synthetic motor oil but it's been a few years since then and didn't know what everybody else was using. Any new advancements where I should use any other brand?
1996 Ram 1500 4x4 with the 318 motor
That 318 will eat full synthetic for lunch.
On my 318 on my old 1997 Dakota, I had to run conventional oil because ANY synthetic would disappear quickly. Even from remanufactured state of the engine.
I use Penzoil synthetic blend in everything I have now. It's done so well across the board on so many cars here for years now.
It leaks on the side that they made it fun to get to on the v10. I believe the intake has to come off as well.
That would be the passenger side.... Yeah, they hid that one REALLY well.
A synthetic oil tends to clean better than most conventional oils, so, what is a small leak now, will most certainly get worse. Given the way my lifters rattle at startup, I am REAL reluctant to go to a full synthetic oil as well, they tend to allow the lifters to bleed down too fast. I have the stuff to change mine over to the Valvoline Max Life. (which is a synthetic blend...... we'll see how that goes.) I just want to run some cleaner thru it before I change it. (which is in the crankcase now....)
Granted I've only had my truck for a good 3000 miles, I just wanted to share my experience.
She had 136 when I got her, about 139 now. I changed the oil as soon as I got it, even though it was "tuned up" before by a shop. I threw some pennzoil platinum high milage. I haven't noticed any leaks, at least any that drip. If you decide to go synthetic, go with a High Milage synthetic if possible. It will help with any leaks. Also, it didn't take long for the synthetic oil to get dirty. I also threw in 5oz of Seafoam and 1/2 quart of Marvell mystery oil just recently when she needed a drink. It's good, if you switch, to maybe put some cleaner through, or with the oil when you add it. No lifter noise or anything. And I don't even know the previous service history of mine, but I would highly reccomend the PPHM.
