Replacement molded carpet
Old 03-19-2017, 02:08 PM
rob98801's Avatar
rob98801
rob98801 is offline
Default Replacement molded carpet
My 2007 Dakota Sl Extended cab 6 speed 2WD has a worn out carpet. Looked at OEM way to much $.
After market MOLDED carpets seem to stop at 2004.
I need measurements to see if I can make the molded carpet for the 2004 fit in the 2007.
Thinking? the pan molding is different enough to foil the project?
Can the 1997-2004 Dodge Dakota - Extended Cab Carpet, 5 Speed, 2wd FIT the 2007 Dodge Dakota - Extended Cab Carpet, 6 Speed, 2wd ???????????
Old 03-20-2017, 08:50 AM
Jaded's Avatar
Jaded
Jaded is offline
Think the 3rd gen is a bigger cab.
The 2005 Dodge Dakota was 3.7 inches longer and 2.7 inches wider than the 2004
Old 03-20-2017, 12:44 PM
rob98801's Avatar
rob98801
rob98801 is offline
Thanks for the reply.
I don't why the aftermarket providers of carpet stop at the 2nd gen unless there is a copyright or patent that hasn't run out yet.
Old 03-20-2017, 03:37 PM
jkeaton is offline
Lack of demand more than likely.
Old 03-23-2017, 09:53 AM
dakotaff's Avatar
dakotaff
dakotaff is offline
There are aftermarket carpets available, some stop at 06 (same as 07), but they are out there.
Just a few below:
http://www.jcwhitney.com/1987-2006-d...87-2006j1.jcwx
http://www.stockinteriors.com/AutoCa...33&ModelId=646
Not sure how well they actually will fit though.
Old 03-23-2017, 12:53 PM
rob98801's Avatar
rob98801
rob98801 is offline
Entering 2006 instead of 2007 info for the extended ST cab shows a fit, changing to 2007 both show a "no go". I think I am going to order a 2006 carpet and see how good bad it fits and return even if it cost the shipping.
Old 12-04-2017, 01:21 PM
JD Smith's Avatar
JD Smith
JD Smith is offline
I am in the same situation. Were you able to cut down the quad cab and make it fit?
Old 12-04-2017, 02:15 PM
rob98801's Avatar
rob98801
rob98801 is offline
I got side tracked for a bit of time but thinking about pulling the trigger on one of the Stock Interior carpets sometime after the holidays. I'll post when I try it.
