[5th Gen : 08+]: Dual Temperature Control Not working properly
Old 03-21-2017, 10:18 PM
heaviekevie's Avatar
heaviekevie
heaviekevie is offline
Default Dual Temperature Control Not working properly
Please help. I have a 2009 Grand Caravan with dual temperature control ***** ..one for the driver and one for the passenger.
I can't regulate the temperature on either side with the heat control *****.
When new...once I reached the desired temperature I am pretty certain I could adjust the temperature up and down by turning the **** to red or blue (without the fan running)
Now however ...the heat and cooling ***** do not seem to work unless I turn the fan on.
It gets too hot....I move the **** to the coolest (blue) setting and I continue to get heat....until I turn the fan on ..then it will cool off.
When it gets too cool I turn the **** back to warm (red) and I get no heat until turn the fan on.
I can not regulate the temperature without a two step process of turning the temperature **** and turning on the fan.
Can anyone help me with this or what needs to be replaced. Thanks
Old 03-22-2017, 07:52 AM
jkeaton is offline
Flush the heater core. Common problem on dual zone temp control models.
Old 03-24-2017, 12:30 PM
heaviekevie
Default dual zone temperatue contol problem
The heating and cooling work fine so I do not think the core is clogged...the problem is that I can not adjust the temperature without turning on the fan. Do you still feel flushing the heater core will solve the problem...the last time I had it in they said i may have to replace the defrost door that is internal to the heater box. Thanks for your reply
Old 03-30-2017, 09:34 AM
Dikeryn's Avatar
Dikeryn
Dikeryn is offline
If the fan is not on, the system is off, so the temperature control ***** will do nothing since no air is moving. For it to operate, the fan has to be on to at least level 1.
Old 03-30-2017, 11:31 AM
jkeaton is offline
This. The fan has to be on for the system to work.
