2004 dodge dakota 4.7 auto trans cranking problems
Hello I have a cranking problem on my dakota.I just pulled my trans back to replace my rear crank seal.Truck ran great but had bad seal leak.
I did job and now,after all put together it won't crank over.Power comes on and gauges lite up but doesn't crank.I have 13.5 volts to starter and checked all fuses their good.I checked the term that comes from range sender to starter relay it should be grounded at relay to crank starter no ground there.I checked all wires,coming from trans they seem good.
I can't find a diagram to see where the neutral safety switch is.There is one sender on pass side at back of pan four wires is,this the range selector?
Thanks
Thanks
