2011 dodge durango rear tire issue
I'd recommend you take the vehicle to an independent shop for an alignment, or at least an alignment check. Make sure the ride height is checked at the same time. Maybe it just looks like the wheel is angled. A decent alignment system and tech that understands how to use it should be able to quickly confirm if it's an issue or not.
Do you notice any abnormal tire wear?
-Rod
-Rod
How long ago did the dealership perform the service for you? Did you have them address it again at any point?
Kori
Dodge Social Care Specialist
