Error code 303 455
Old 03-30-2017, 05:16 AM
Fred Olden's Avatar
Fred Olden
Fred Olden is offline
Default Error code 303 455
Ive done everything tune up injectors evap hoses purge sylinoid new breather hose cleaned throttle body new pressure sensor new gas cap new crank sensor new still getting same dam codes what else do i need to do ?take off the dam manifold and change gaskets i cant believe this freaking truck u guys have any advice
Old 03-30-2017, 07:39 AM
jkeaton is offline
What year, what engine, mileage?
Old 03-30-2017, 07:56 AM
Fred Olden's Avatar
Fred Olden
Default Error terror
03 dakota sxt v6 4x4
Old 03-30-2017, 07:59 AM
Fred Olden's Avatar
Fred Olden
185 thousand mi
Old 03-30-2017, 08:03 AM
Fred Olden's Avatar
Fred Olden
I wish i could just talk to a dakota mechanics specialist and pick his or her brain for 10 minutes would lead me in the rite direction
Old 03-30-2017, 10:34 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
P0303 misfire cylinder #3
P0455 evap leak monitor large leak detected
How's the plug on #3 and the wire?
It could be a rotted fuel filler, it's a common problem. Get someone to smoke test the system for the leak.
Old 03-30-2017, 10:41 AM
Fred Olden's Avatar
Fred Olden
new plug new wire all tune up double checked connection all good new fuel pump ill check fuel filter
Old 03-30-2017, 05:08 PM
magnethead's Avatar
magnethead
magnethead is offline
Large leak sounds like back of the truck. One of the two 5/8 lines at the charcoal can, the 3/8 line at the charcoal can, or the fuel filler neck/filler neck vent tube.
Old 03-30-2017, 08:40 PM
Fred Olden's Avatar
Fred Olden
checked and replaced evap hoses but ill check neck filler
