Ck the power steering switch for any fluid leakage, if you have a leak. the wire harness and o2 sensor may have p/s oil in the connectors, also ck the connectors at the PCM too. Yes a leaking p/s switch can push fluid up to the PCM.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
