2nd gen Dodge Ram stuff,axle,hubs,gears,brakes, etc.
From a 1998 dodge ram 1500 4x4.
Dana 44
All single piston....
Driver ABS Caliper - $15
Passanger ABS Caliper - $15
Driver Non ABS Caliper - $15
Passanger Non ABS Caliper - $15
Basically new Pads - $20
Pads w/ 15k on them - $10
Dana 44 - 3.55 gear - $20
Carrier empty 3.55 and higher(num lower) - $20
Carrier loaded 3.55 and higher(num lower) - $30
Dana 44 spider/side gear + cross pin - $10
ABS hub BRAND NEW, napa, timken bearings - $115
ABS hub, 2000 miles, napa, timeken bearings - $65
ABS hub, 1.5 years old, napa, timken bearings - $40
If you don't have ABS, just cut the wire off and run it.
Also have hub to knuckle bolts I'll include if wanted.
(1) CAD - working when removed, one hole is chipped - $25
Dana 44 diff cover - $15
pinion yoke - chysler 7290 joint - $15
(2) intermidate shafts(will not fit dana 60s) - $10 a piece
Chysler 9.25
Chysler 9.25 , 3.55 gear - $20
(4) axle shafts w/ lug studs - $25 a piece
Diff cover - $15
Other stuff.
Skyjacker 5" short arm LOWERS, 2 of them, a lil dented on the bottom, need two new bushings, - Make me an offer
(2) stock lower control arms - make me an offer
Bumper brackets - make me an offer
SHIPPING NOT INCLUDED... LET ME KNOW WHAT YOU WANT AND GIVE ME A ZIP CODE AND I'LL PM YOU A TOTAL.
MIke.
Dana 44
Chysler 9.25
Diff cover - $15
Other stuff.
MIke.
