I recommend this one http://cpwstore.carpartswholesale.co...S-V218205.html or this one http://cpwstore.carpartswholesale.co...V4401171K.html, they are only like $70. They are exactly the same and are clones of the mopar/AEM intakes. The only issue w/ these is that the bracket on the filter end may break, but it's easy to rig up your own bracket if that happens. I have the spectre which is about $160 and is the same as the one's above except it has has moved the bracket to a sturdier location.
__________________
Silver Truck Club Member #12
Mods: Spectre CAI w/ open trueflow filter, Taurus e-fan, Magnaflow muffler dual-in single-out (factory y gone), Jet stream scoop, jet stage 1, ASP UD pulley, Line-x
The one's I posted go straight to the TB, like this one
__________________
drilled a hole and used a section of PVC tube that the sensor fits in. Then cut the length and epoxy glued it in...same with the breather tube for the heads.
same thing i did but i brought the filters down to where fog lights would be
__________________
true dual flowmaster super 44, black chrome tips, custom dual intake, powerwire, halo projectors, green underglow, roll pan, pioneer head unit
