Provide your Dodge Ram with a smooth ride by installing Pro Comp Lift Kit!
If you're looking to provide your Ram with the performance it needs to conquer any terrain and get the aggressive look that you always wanted, we have a solution for you! Pro Comp 6" Stage 1 Front and Rear Complete Lift Kit is designed to deliver superior suspension performance and ensure that every component is able to withstand off-road abuse.
Pro Comp Lift Kit is engineered using the latest scanning equipment and computer-aided design technology. All the parts are laser-cut, CNC-formed and robotically welded. It also incorporates one-piece drop down cross members and high strength extended steering knuckles that are compatible with the factory stability control.
Here are some of the main features:
1. Lift Height: 6"
2. Max Tire Size: 35X12.50
3. Requires 18" or larger diameter wheels
4. Includes impact struts and shocks.
With Pro Comp 6" Stage 1 Front and Rear Complete Lift Kit installed your Ram will have a new aggressive stance and be able to handle any terrains! PM me today if you need a quote or leave your comments below.
1. Lift Height: 6"
