DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   1995-2000 Dodge Avenger (https://dodgeforum.com/forum/1995-2000-dodge-avenger-84/)
-   -   avenger won't start (https://dodgeforum.com/forum/1995-2000-dodge-avenger/155942-avenger-wont-start.html)
bakedc Apr 4, 2008 05:07 PM
avenger won't start
I have a 96 with a 2.5. It won't turn over & the antilock light stays on.Any ideas? Appreciate the help.
bad venge Apr 4, 2008 05:51 PM
RE: avenger won't start
Do you hear the fuel pump kick on ???
bakedc Apr 4, 2008 06:10 PM
don't know
dynamiteplaya3 Apr 4, 2008 07:01 PM
to check fuel pump.... turn the key to the on position. listen for a quick humming noise. thats the fuel pump working
bad venge Apr 4, 2008 08:03 PM
or you can pop the rear set bottom off and open the hatch behind the drivers side and check for voltage ...
bakedc Apr 6, 2008 02:04 PM
fuel pump doesn't kick on
bad venge Apr 6, 2008 02:26 PM
Fuel Pump relay ... Info is in the stickies above
bakedc Apr 6, 2008 05:00 PM
Thanks for your help,but I didn't see any stickies. Which relay is the fuel pump?
bad venge Apr 6, 2008 08:56 PM
https://dodgeforum.com/m_554757/tm.htm ;)
Sroufe7 Apr 6, 2008 11:15 PM
If the engine does not turn over...Why would the fuel pump turn on?
Check to see if the starter is getting power. It has one thick wire going to it, which should have battery voltage all the time.
The other wire should have 12 volts when you try to start the car.
© 2026 MH Sub I, LLC dba Internet Brands
