Weird sound from engine following RPM.
Hi guys , I am new to this forum and would need help.
I recently bought a 98 Avenger 2,5L V6 Automatic with 190.000 km on it. ( around 118,750 miles ). I paid the car 950$. The problem is: You know when you reverse a car the sound it makes ? My car does it all the time. It follows my rpm and does it at idle too. Sound like this http://www.youtube.com/watch?v=GlTKM8wCMU4 ( not the engine itself but the weird sound ) What could it be ? Thanks. |
evap solenoid ?
Forgot to say the car works well , Stay idle perfectly, Starts good and Doesnt have the check engine light on.
Evap solenoid
I will look that , Where is it located ? And is there a way i can test it to see if it properly works ?
I just recorded the sound my car makes. here it is http://www.youtube.com/watch?v=fdiS4sketxQ This is a cold start , Not really cold outside ( like 10 celcius ) but the car has not run today. |
I found out where the sound comes from , But i dont know much about engines ( always willing to learn more ). This is the part that does the sound
http://img855.imageshack.us/i/img001...042911142.jpg/ http://img4.imageshack.us/i/img00156201104291114.jpg/ |
Thats BAD .. under the plastic cover is the timing belt ... you might have a bad tensioner /bearing /or the belts coming apart.
The 2.5 is a Zero clearance motor if you loose the timing belt ot even skip 3/4 teeth the motor will destroy itself |
Thanks. I dont use the car alot but will still make it a priority. What is the name of the part showed in the picture ?
The Plastic part is the timing belt cover
what i mean is the part that has the belt on. Is it the A/c Compressor ?
Oh and i checked the belt and it looks good so it might be the bearing or inside de compressor something is rubbing. I just learned that my friend has a old stratus that has been accidented but the engine still works on it so luckily the parts i need might still be good. |
