98Avenger Speaker Install Q's?
(May have been asked but... )
I have a 98 Avenger ES that I am planning to get new Tweeters and Door Speakers for. It currently has all stock speakers. I have 2 main questions/concerns. A) Does the dash need to be removed to access the Tweeters, or can I simply "plop" or pry the plastic cover off to access the Tweeters?? B) In order to install the Door Speakers, for my model of car, will I have to take off the door panel entirely, or can I again simply but carefully "plop" or pry the plastic cover off with a screwdriver to access the Door Speaker?? I'm hopeing it will be the simple way and not dismantleing my whole car. -Thanks |
RE: 98Avenger Speaker Install Q's?
Frst the dash tweeters just pop out using a small screwdriver.Yes you wll have to remove the entire door panel.Its pretty easy once you get the screws out. just be careful of the wiring going to your window switch.the peice of trim holding your window switches is kinda fragil.The door speakers are stock 6 3/4 and unless you can find good speakers that fit then you will have to use adapters..I went with a new set of infinitys and they fit beautiful after i mounter the speaker to the adapter and hacked off the excess screws.they fit nicely into the factory baffles.Also infinty makes a set of tweeters that should fit right back in the same location as stocks.Hope ths helps.
Locking the thread since it's a double post and the other one has more answers;)
| All times are GMT -4. The time now is 05:12 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
