U-joints replacement
#21
RE: U-joints replacement
if you guys don't have problems then i agree, they are tough enough. i do have a question about them though, i checked the shed and found two joints off a comanchee i had. the joints are the same size but one has shorter caps, the caps are the same diameter though. i also noticedthe clips goon the inside on one and the outside on the other, is this what you mean by a smaller joint? if so there should be no loss in strength just a different design.i did look under thedakota just to be 100% sure and they are the exact same.
#22
#23
