Seal between inner joint housing and diff
I recently checked my differential and the front differential was low. I noticed there is a slight leak where the inner joint housing meeting the differential (I assume I got the names right). Is there a seal in here? I couldn't find anything listed for sealing when you reassemble the CV or differential. I am sure I am just missing something in the manual, but anyone know what to do here or what the seal is?
It would be front axle seal. You could always check the part manual in the FAQ. Part # 5206 8535. http://www.napaonline.com/NOLPPSE/(S...995_0213976205
Cant believe I didn't think of that, instead I kept reading the service manual over and over. Thanks for the help. I think I will need two of them as both sides are leaking.
