Diagnose This... if ya can 1991 Dkta 4x4
She smokes like crazy (valve guides no doubt) I can overlook that. Thus far I have been chasing down vibration. Recently... New front wheel assembly berings. Done. Rear axle berings. Done. New driveshaft to rear includ. new universals. Professionally done. (I messed up the last set in a vice) New transmission tail cone bering and seal.... Also I just had the transfluid flushed and changed out. The fluid actually looked pretty good still. Tires I know I need. Vibration now for the most part gone - most of which left is caused by this 6 banger. Now the big question is after I came to a complete stop... then accelerate (modestly) I will get this thud or mild bang (not loud) just felt in the seat you see about a half a second after lift off. If it was the uni's I would and did get a bang right off the bat. So I am wondering if this is caused by something in the rear end or a transmount shifting forward when I stop amd sliding back when I take off. I did look up under and noticed that where the trans is mounted to the mount due to the dis-similar metals touching it looks as though the trans casing is disolving away - if you follow? The mount rubber still "looks" alright. Yet as I say where the steel on the mount and the aluminum of the trans meet - not good. Pretty silly who ever engineered that. I suppose that is how parts are sold. Anyhow about this bump or thump or clunk or bang slightly delayed after take off... any clue?
I really like the truck especially now that I recently sunk a ton of loot into it. We have formed an attachment indeed. I am getting ready to tow a trailure load of tools back to the Upee (MI) and this clunk thing has me a bit concerned.
RE: Diagnose This... if ya can 1991 Dkta 4x4
Definately check your mounts, on the tranny and in the engine bay. Make sure they are tight and the rubber isn't torn. As for the mount that I think you are talking about, there should be a rubber barrier between the tranny and the mount. If that's not there, then you need to get a new mount.
check your rear diff for any slop. i had the same problem with my 1990 ramcharger and all dodges have some play in the drive line. your carrior bearing could be bad or pinion bearings to. and if it is 4 wheel drive it could be in the transfer case. look at all you mounts to.
Kyle
Kyle
