Dash lights
Dash lights
I am running into some issues with my dash lights speedo/heat/tach etc. also the interior light doesn't work unless turned on manually. I checked the fuses and according to the diagram the cigarette lighter should not be working aswell if this certain fuse is blown but regardless i checked them all seem to be fine. any ideas? i can't think of anything else i'm sure it has to be a simple solution thats right infront of my face lol.
Thanks
Nathyne
Thanks
Nathyne
damn that would have been far to easy to fix haha. well i checked all the bulbs (knew this was very unlikely to be the problem) and cleaned both connectors on the back of the cluster and still no luck. going to check the grounds next time i feel like going to my garage and freezing for a while...
Hey, at least you have a cold garage to pull your truck into. My cold garage has a dead Silhouette, tiller, pond (that hasn't been installed yet), lawn mower, and a host of other crap that will not allow another vehicle to be pulled in. I was changing a radiator in the snow not too long ago. Sure would've enjoyed my cold but dry garage.
