hey just did mine if it like my 89 it in the tank u have to drop the tank also the leads are sodered on to the pump i just cut and repaced mine wile uer in thear u should replace the straner fuel lines and filter lines to it as well it only 15 psi so any line will work the sizes are 1/4 5/16 2' should be good on a 4wd u have to drop the skid plate then the tank straps after thal thear is a hose clamp that holds the asembly in dont forget the filer and vent(thears two 1 to the filler and 1 to the frame)
i remember the days when you replaced those mechanical pumps for 10 bucks in 10 minutes. i know the 87 has a carb on it (only year) not 100% on it but i think your right crazy. and everyone wonders why i want an old school dak for off road (not racing).
