Turbo Question
If the point of a turbo charger is to force more air into the engine causing better performance why would you not use a small shop air compressor put a connection nipple on the air intake filter housing put the air compressor in a tool box in the back of the truck run a air hose to the engine and control the boost with a simple valve in the cab of the truck. Now if there is some fundamental flaw i am missing other than the cool sound of the turbo vs the sound of an air compressor i would like to know!
Thanks |
I'm sure someone has tried it. But you need more Volume into the engine then PSI. Think of a normal air hose nozzle vs a leaf blower. The air hose may have more PSI but it will not be able to put out the volume a leaf blower could put out.
But if you want hook up a compressor and post up a video and see what your 0-60 times do go for it. Heck someone has hooked up a leaf blower to the engine and made 10more HP on the dyno. |
A 318 at 5000rpm is inhaling 414 cubic feet/min of air. You will not find an air compressor that will flow that much air.
Exactly. A full air compressor tank, if you could unleash the air into the intake at a high enough volume, would last maybe a few seconds.
Get a real turbo, they're a lot more fun :D |
A hood scoop will give you a couple extra horsepower with the ram effect and even more hp with the cold air it will be sucking in. When I am cruising around at 45 mph there is a significant amount of air coming through the floor vents and the dash vents with the AC and fan off.
if you go turbo, stay away from v-tech...lol when i drive down the main drag by my house they are always broken down on the side of the road...lol
Originally Posted by shadowthedakota
(Post 2245907)
had to add that in there ;) |
