1993 dakota error codes
have a 93 dodge dakota and did the code check and seems to flash 32 7 55. Any thoughts was thinking of unpluging battery to reset and trying again.. please help
Hey, I have one, turn your eng. off then turn your inition on and off three times to reset the PCM.......code 33 is A/C clutch relay circuit.......code 7 I don't know ?.......55 is the end of the codes. hope this helps you......an OBD code reader can help!!
dbreedlove |
