Need help. 92 dakota gremlins
I recently bought a 92 dakota sport 3.9 v6 5spd with 90,000 on it, here's the problems. I was told by owner that he received the truck from a relative that passed away and truck had sat inside a barn for a few years.. the new owner drove the truck but was having problems with it just dying and then starting when it wanted to... it was also blowing fuses as well . He thought fuel pump was going and installed new pump but dakota still didn't want to run. He left it sit 1.5 yrs till I bought it. I used spray start but didn't fire. I changed the cam sensor /hall effect and used spray start and it started to run then died and was the last time . It wouldn't fire any more after that one time. Got to looking on dash there was no check engine at all. Pulled ecm with one my friend had from a newer dakota but it was from a 3.9 but auto.... I now have a check engine light and it says code 11 45. 55. What should I do next ?
With an auto ECU, the 45 can be ignored for now; that's a bad transmission solenoid error, according to http://www.dakota-truck.net/CODES/codes.html . 55 is "END OF CODES", so that's not a problem.
The 11 is. It says the crank and/or cam sensor is bad, so if it's a Magnum (kegger style manifold, 6 fuel injectors) then I'd do the crank sensor also. Plus, be sure to use Mopar parts; there's been a LOT of people who have had consistent problems with both, but switching back to Mopar parts fixes the problem. RwP |
Originally Posted by RalphP
(Post 3331352)
It might be.
Could also be bad contacts; these trucks are old enough that some "gremlins" are fixed by removing/connecting things (science: Oxidation builds up on the contacts, removing/reconnecting wipes the contacts and polishes the oxidation off. It's not magic, it's SCIENCE!!!) So if you put yours back in it might work just fine now. Also, did it not even give a "55" code when you did the key dance? RwP |
No it didn't give any codes with the computer it came with , in fact it didn't even light up the check engine light. Only when I plugged my finds computer from a newer dakota did it give me codes.
I called O'Reilly auto they can get me a ecm for about 170 don't need a core. Don't mind it if it woukd get my truck running, 90k original miles she should have a lot of life left. That or I'm selling it. Lol
