Black substance in anti freeze overflow
Have you noticed the truck running any different? A sputter at idle, missing, etc.?
Has anyone put any additives in the antifreeze? Some of these can cause problems.....
Has anyone added antifreeze? Not all antifreeze are the same and some dont mix.
If not, this is what I would do in this order.
1. pull dipstick and look for moisture in the oil. Usually will be signs of white foam. If none then move to 2.
2. Drain antifreeze and flush system, including heater core.
3. refill and watch to see if it comes back.
I will try to get pictures today at lunch..I’m wondering if someone didn’t add a stop leak in the antifreeze... just bought the truck for $200 so can’t xomplain
