The glass in electric windows is the same as the glass in manual? I have manual windows but one of the previous owners had window tint that makes it feel like I'm driving through a car wash. I've tried taking it off with marginal success.
Sorry, I have a 95, so if it's not showing any different numbers shouldn't be a problem. I found a 90 electric window at a junkyard, I thinking i could just swap out the glass.
Ok so I've been trying to keep this swap as a last resort. So obviously the junkyard disconnected the battery, how would I go about getting the glass out? I have seen people take a jumpbox to test motors and such, but I don't remember how.
Put power to the positive wire and ground the other side to the body. ?
If it's at the junkyard, one possibility is to follow the wiring from the motor back to its connector; cut the connector on the body side of the wiring harness; and jump 12V into the two wires that run to the motor. If it's running the wrong way, then swap which one is +12 and which one is -12 off the jump box.
